cancel
NX CMM: element calculation algorithm
Whatever selected both on element definition or element tolerance (e.g. diameter ), postprocesor alwas inserts command GEOALG/CIRCLE,LSTSQR  (GEOALG/MODES,LIMSIZE=AVG postprocesor DMIS 3.0) whereas I need algorithm according to ASME Y14.5M - MINMAX,MAXINS,MINCIR.
CMM command NX function is not solution as every dia must be evaluated in two ways, so inserting such command manually is nuisense.
How to achieve what I need ?
