NX Cam Postprocessors
Hi Everyone,
NX Cam Newbee here.
We have a customer that recently upgraed from NX Cam 10 to 11. After the upgrade, the attached Postprocessors are not working (Error 1770002).
Any help would be greatly appriciated.
Re: NX Cam Postprocessors
There is a file missing.
User's Tcl: absoute_cnc_3axis_user.tcl not found!
Hi Glenn
Looking at the "Auto Tool Change" event there is an "N" block which was causing the error. It seems they want sequence numbers are turned off until the tool change. I replaced the "N" block with MOM_set_seq_on to turn the sequnece numbers back on. I tested with single and multiple operations and get no errors.
Attached are the updated popsts.
If you have any other questions please ask.
Paul
Much appriciate Paul
Anytime.
Hi...i am a new user here. As per my knowledge they want sequence numbers are turned off until the tool change. I replaced the "N" block with MOM_set_seq_on to turn the sequnece numbers back on. I tested with single and multiple operations and get no errors.
