NX Output XY and UV coordinate unsuitable for Mitsubishi wirecut machine
Dear all,
In NX wirecut manufacturing, NX automatic choose underface to set XY plane for output, where can I setup as image bellow (XY plane is the top of taper). 3D file in attched. Thanks
Re: NX Output XY and UV coordinate unsuitable for Mitsubishi wirecut machine
CHANGE THE MCS
Push a button Cutting Parameters and swap Upper Plane and Bottom Plane Wire.png
