NX Solid Tool
Currently we want to creat special solid tool to use for milling ( like, probe in solid group in nx ). I do not want to use user define to creat form tool. So.... I do not know in NX it is possible or need second development?
UG3.0
UG6.0
NX10.0.35
NX11.0.1
UG_NX is my favorite !!!!!!
Re: NX Solid Tool
You do this just like a probe, but select Generic as the class when you export, instead of Probe. Basically, you open the model of your solid tool, create a solid_tool setup, create a generic tool, and export to the library.
This is documented - search for "Create a solid probing tool for export to a library".
Mark Rief
Retired Siemens
