NX cam template - custom operation problem
Hello everyone,
I have some question about cam templates (operation).
I have followed to the Mark guidance : https://www.youtube.com/watch?v=52ONaz43RoI
and I met a couple of problems Smiley Sad
I made my operation by using the ready-sources in path below :
C:\Program Files\Siemens\NX 10.0\MACH\resource\template_part\metric\mill_contour.prt
My operation is named as MY_CAVITY, the image and prt. file with template atribute parameterization is attached to the annex.
I reset the NX program and unfortunately, after proper selection of CAM environment and mill_contour group, I do not see operation which I made before. I add the operation picture named as my_caivty.jpg to the source path:
C:\Program Files\Siemens\NX 10.0\MACH\resource\template_part\images
Operation MY_CAVITY has been saved as "object can be used as template".
Maybe I missed something, I change nothing in driver file MACH\resource\template_dir\template.dat because I am using standard metric template which I mentioned above.
PS. The main file mill_contour.prt which was modifed is unlocked and saving is enabled
Engineering >> NX10.0 Performance in the making
17 REPLIES 17
Re: NX cam template - custom operation problem
Make sure that you customize the files contained in the update folder, which is used instead of the regular location, if a file is present there too.
I would not even edit the files in the installation folder of NX, since they are always replaced by an update without notice.
Always modify a copy of the resource folder and point the appropriate ugii_env.dat variable to that folder.
I dont understand... Can You show me the solution more clearly?
If I am using METRIC standards, why I cant easly edit the metric cam group?
You suggest to make a new Folder for handling templates parts ?
If so then I have to made some changes in template.dat
C:\Program Files\Siemens\NX 10.0\MACH\resource\template_dir
Ok, now I understand - forgot about UPDATE folder.
Everything is working now as in annex - thx Stefan Smiley Happy
Last question - where I can update the icon of operations?
I know about CAM_ICON but I cant find folder to replace or add new icons.
The path is the application sub-folder of UGII_SITE_DIR, UGII_GROUP_DIR or UGII_USER_DIR.
I think UGII_BITMAP_DIR (not sure this is the real name) could be used too, I think.
UGII_BITMAP_PATH=
is where you need to place the bitmap images (.bmp files)
John Joyce, Manufacturing Engineer,
Senior Aerospace
NX 11.0.2.7 Vericut 8.0.3 - Statements and opinions are mine alone and do not reflect
the opinion of my employer or any other member of the human race
Users - DO NOT change the template parts in the updates folder. This area is for Siemens to provide updated files in maintenance releases. When you load the next MR, your changes will likely be lost. You should make a copy of the resource folder, and make your changes there.
http://community.plm.automation.siemens.com/t5/Tech-Tips-Knowledge-Base-NX/Getting-started-with-NX-C...
Why are all our settings wiped every time there is a MR release?
Can't someone figure out how to store these as values in an excel sheet or something? Upgrading NX is one of the worst flaws of the software....
Every time there is an update you have to go back and change all your defaults...
Dennis Rathi
Creations Unlimited
Hello, thx for answers but I dont need bitmap path - You can see that I made some configurations about bitmaps (watch annex above) because all of my templates have visible bitmaps (folder C:\Program Files\Siemens\NX 10\MACH\resource\template_part\images).
Just I want to make some new operation icon like Mark had in his presentation (my pocket).
I was looking for the Nx folder which keeps operation icon but I can not find it ...
Mark - so I need to create new folder for my templetes?
Is it risky to keep those files in the update folder?
Mark, ok I created a new folder for templates , template.dat set for new folder & I made some backups in case of a new update (MR).
But steel I cant find how You made a new icon operation of my_pocket xD
