12-14-2017 04:48 PM
Solved! Go to Solution.
12-14-2017 06:04 PM
Before I assume...
Turning?
Face threading (no existing template operation) vs ID/OD threading (for which template ops exist)?
12-15-2017 06:59 AM
Yes, I means lathe face threading. We can use OD ID to turn face threading?
12-15-2017 09:44 AM
I haven't tried it, but I would assume if you set the tool angle (0/180 deg) and crest line & depth/root line correctly, you could get face threading to work.
Then you need to deal with the issues in the post (correct G codes & parameters)
