NX shopdoc html depth of cut
Hi
How to set shopdoc template for Depth of cut and maximum Z depth?
I check not have any MOM.... for depth.
Thank you.
NX 10.0.2
Windows 7
Re: NX shopdoc html depth of cut
for mill_planar :
mom_cut_level_initial_depth
mom_cut_level_last_depth
mom_cut_level_max_depth
mom_cut_level_min_depth
mom_cut_level_side_stock_increment
Production: NX11.0.2.7,VERICUT 8.1.2
Development: Tcl/Tk, Gnuplot
www.adgroupe.com
There are mom variables as you see for depth per cut.
If you are looking for the lowest Z, for example, it is not a simple variable - you need to keep track of the depth.
I would start be reviewing https://community.plm.automation.siemens.com/t5/Discussion-Forum-NX/Shop-Documentation-Lowest-Z-Dept...
Mark Rief
Retired Siemens
