NX unit conversion - ERROR: Standard C++ exception caught
Hi NX users,
I am new to SIEMENS Products & Solutions. Can anyone guide me, why am i getting this error - standard c++ exception caught while doing unit version.
C:\Users\admin>"C:\Program Files\Siemens\NX 11.0\NXBIN\ug_convert_part.exe" -in "D:\Bhoopathy_P50\Sonata\SIEMENS\SABA\NX 11.0.1 CAM Manufacturing Fundamentals\parts\mnf03_area_mill_cut_regions.prt"
NX Units Conversion Program
Opening: D:\Bhoopathy_P50\Sonata\SIEMENS\SABA\NX 11.0.1 CAM Manufacturing Fundamentals\parts\mnf03_area_mill_cut_regions.prt
*** ERROR: Standard C++ exception caught. See system log for details
D:\Bhoopathy_P50\Sonata\SIEMENS\SABA\NX 11.0.1 CAM Manufacturing Fundamentals\parts\mnf03_area_mill_cut_regions.prt - *** ERROR: Standard C++ exception caught. See system log for details
0 files successfully converted
0 files generated warnings
1 file failed to convert
thanks in advance.
Best Regards,
Bhoopathy
Best Regards,
Bhoopathy
Solutions Consultant - India
Sonata Software Limited
Re: NX unit conversion - ERROR: Standard C++ exception caught
Can you open it in NX (interactively)?
If so, maybe do a File -> Utilities -> part cleanup & save, then try?
Otherwsise, you may have to report this to GTAC.
Hi Ken,
Thanks. Still same error. Let me check with GTAC then as you recommend.
Best Regards,
Bhoopathy
Best Regards,
Bhoopathy
