NX10 Shop Doc toollist multiple adjust-register
how do i output one tool with multiple adjust register ?
One Line for each option.
For example
Tool Number           Adjust Register
T1                              1
T1                              2
Thanks in advance
Peter
Regards, Peter
Re: NX10 Shop Doc toollist multiple adjust-register
You know Tcl... ?
@mkn
Production: NX11.0.2.7,VERICUT 7.3.3
Development: Tcl/Tk, Gnuplot
www.deshors-tiremold.com
yes, what do you mean ?
Peter
Regards, Peter
ok , Smiley Happy
-turn on the review tool to see the variable which you need
-for each operation add > Adjust Register variable and tool number variable
-end of program > display values
I will deal like this
# start of program
array set list_adjust {}
#each operation
lappend list_adjust($var_tool_number) $var_adjust_register
# end of program
# display values
# example :
# T1 (10,99) T10 (20,102) T2 (33,35) array set list_adjust {1 {10 99} 10 {20 102} 2 {33 35}} foreach {t key} [array get list_adjust] { foreach adjust $key { MOM_output_literal "T$t > $adjust" } }
result :
T10 > 20
T10 > 102
T1 > 10
T1 > 99
T2 > 33
T2 > 35
if you want a array in the order add in the other list and display values with 'lsort' function.
@mkn
thanks a lot, you´re right.
But i mean, how can i modify the default shop_doc template, to output multiple adjust_register.
Regards, Peter
I don't know shop doc based on excel
sorry
@mkn
