NX10 Shop doc - display output setting
from sime time I am trying to figure out how no to output html shop doc each time I generate excel template. I know that I can disable "display output" setting and get only excel output. How can I change this setting permanently for every new manufacturing assembly I create? Should I change any template setting and save it? If yes, in which template? Thanks for hlep.
Regards Jarek
Settings below:
Jarek, CNC Programmer
Production: NX10.0.3.5 MP19
Testing: NX 12.0.2.9 MP4
Development: Tcl/Tk
3 REPLIES 3
Re: NX10 Shop doc - display output setting
If this is available, then it would be a customer default.
If I remember correctly, this is not a customer default yet, so you will have to create an enhancement request at GTAC to speed up its implementation.
Search the customer defaults for "display" and check the results of the manufacturing section.
Stefan, thanks for reply. I have checked customer defaults but couldn't find such display option. Enhancement request was sent to GTAC . Option will be implemented in newer NX version.
Development: Tcl/Tk
I had opened a similar enhancement request in 2012 as ER#1906259, it was cleaned up due to it being open for such a long time.
Would you mind posting your ER number here, so I could ask for being added to your ER to give it more weight ;-)
