NX10 streamline problem ?
Dear all
I am using NX10.0.2 MP2. I use VARIABLE_CONTOUR operation and use streamline drive method. I want to move first engage from top side to left side(red mark) . I do not know . How to do it ?
thank you.
Re: NX10 streamline problem ?
Either...
Select the Flow Curves so that the start point is where you want the engage.
or...
Add a Cross Curve #1 where you want the engage.
Mark Rief
Retired Siemens
