NX10 tool tilt axis ?
Dear all I am using NX10.0.3 MP1 .  I was creat tool by create model and export to libraly (export tool part file )  . When I use operation flow cut and use tool tilt axis option . It does not has tile mode in avoidace method .  What’s the trouble?
Thank you
Re: NX10 tool tilt axis ?
Do you also have standard (parametric) holder defined in your tool?
Because this is what NX takes into account for tilt-option.
Marek Pawlus, NCmatic
Development: C#, Tcl/Tk, CSE
