NX11 Legacy Lathe problem!.. (Urgent)
We have already a manufacturing program which is prepared by “NX10” (but we are still using “legacy lathe”).. When we open this program and generate in NX11; go home point doesn’t seen but actually go home point is already defined in NX10...
Please can you help us!!
You can see the pic. At the attachment file.
3 REPLIES 3
Re: NX11 Legacy Lathe problem!.. (Urgent)
Have you reported to GTAC?
Why are you generating the operation? The old tool path should still be there.
I hope you area aware that Legacy Lathe went on critical maintenance 15 years ago, and has been unsupported for at least 5 years (see SFB-NX-5430). You should be using the Turning module.
Mark Rief
Retired Siemens
Thank you,
We started using the new lathe module.
But we have not implemented it in all operations.
We are now looking for an alternative solution.
