NX11 - Thick lines on created parts
Hi All,
Not posted in a while, recently upgraded to NX11 and can't seem to find the option or customisation for this problem.
I create an assembly, all parts loaded look fine, but then as soon as I create a new part to the assembly, say for example modelling a clamp or stock, it appears with much thicker lines in the assembly. Not affecting my current work but very annoying and doing my OCD no good.
Thanks in advance.
Matt
3 REPLIES 3
Re: NX11 - Thick lines on created parts
ctrl+shift+v
try to  change line width.look at attached file
Also you can select part which has thick lines push ctrl+j and change widht under the font.
NX 12.0.2.9 MP10 / Testing NX 1847 Version 1867
CanikSoft NC Post-Processing & G-Code Simulation
www.plast-met.com.tr
www.caniksoft.com
Brilliant sorted thanks Smiley Happy
FYI there is also a customer default for line width:  Gateway-Visualization-Line tab
That may be just for File-New-Model-Blank, not sure. You can also customize the prt files for File-New-Model-model and a lot of users make custom seed prt files to start with too.
NX 12.0.2
