NX11 Use Latest Updated Libraries
Hi all,
I am currently migrating to NX11.0.0 .
We are using customized library scripts (e.g. everything referred to by UGII_CAM_LIBRARY_TOOL_DIR, ...).
In NX11.0.0 I could not find an update folder for these scripts.
In order to not use the tcl scripts of the update folder I have to disable the new customer default, right?
Thanks in advance!
Best wishes,
Joachim
In production NX 12.0.1.7 MP4
In testing NX 12.0.2.9 MP5
Re: NX11 Use Latest Updated Libraries
The update folder will be present with the first MR usually.
If you use your own customization, I would highly recommend to disable the updates in the customer defaults for templates and libraries, but you must also add the updates to your customization on your own.
There are no updates in a .0 release. These start with 11.0.1. The updates folder is for Siemens MR and MP updates only, not for users. User configuration or customization should be done in your UGII_CAM_RESOURCE_DIR folders.
After 11.0.1, if you see library tcl files in the updates folder that match the ones you customize, then you would need to turn the customer default off, so that your files in resource... are used. Of course, if you see updated files in a MR, you should take a look and see what we updated, and if you need to merge any changes in to your custom versions.
Hi Stefan, Hi Mark,
thanks for your feedback. I have disabled the customer default.
How does NX finde the update folder? Knowing this, I could use this to transition from one version of TCLs to a newer one in my company.
Best wishes,
Joachim
The updates folder is not to be used by customers, it is a Siemens only feature, since files will be changed or deleted without notice by the installation of MRs and MPs.
In addition there is no way to customize it and it is handled internally.
Hello Stefan,
what a pity. Smiley Happy
Best wishes,
Joachim
If a custom script must be updated one would always change the script directly, I see no benefit to do this twice.
@JSchraitle wrote:
Hi Stefan, Hi Mark,
The system looks UGII_CAM_BASE_DIR for the updates folder, but as said before, this is not for users. You should redirect the resource folders.
