NX11 improvements (behind the scenes)
I wanted to start a thread for others who havent gone to 11 yet. Whatever changes were made in the background are HUGE!
Tool path calculation times seem faster
IPW generation seems faster
Tilt tool axis seems faster
ISV of 5 axis machine code is WAY faster
If there was a way to time a process in nx10 and nx11 I'd like to know how? *besides sitting in front of the computer with a stop watch*
NX11.0.1
Re: NX11 improvements (behind the scenes)
Esteemed Contributor
Use a journal that executes the action, but write out the time before and after the process.
Almost all actions can be executed by a journal by now.
You can try this attached journal to get toolpath generation time. I'm sure there must be other versions as well.
Select the operations and run the journal.
LMGi
www.TLMGi.com
Would it be possible for you to post some results from your tests?
I'm interested how much the time difference is...
Maybe also some specs from your system to put things in perspective.
Sven
NX11.0.1
Yes I will try to post some results this weekend.
NX11.0.1
Thanks for sharing with the community!
NX 9.0.3.4
NX 11.0.2
