NX12 Operation Template Customization - Attributes CAM_TEXT, etc.
I am just looking into our hole_making.prt (etc.) customizations in NX12.0.1.7.
In one case we create a new operation with different name and description. In previous releases there were the properties CAM_TEXT, CAM_TEXT2, CAM_TEXT3 and CAM_TOOLTIP.
In NX12.0.1.7 there is a CAM_TEXT attribute with the value "KEYSmiley SurprisedPERATION_DRILLING".
Does anybody know where the key is referring to? I couldn´t find anything in the NX help about this key-value concept
Thanks!
Best wishes,
Joachim
In production NX 12.0.1.7 MP4
In testing NX 12.0.2.9 MP5
5 REPLIES 5
Re: NX12 Operation Template Customization - Attributes CAM_TEXT, etc.
I would say that this will be read from a language resource file for easier translation.
You could check if the translation meets the one contained in the file "%UGII_BASE_DIR%\LOCALIZATION\translations\german\libcamsutilint_german.txt", which contains the "OPERATION_DRILLING" key Smiley Wink
Hi Stefan,
I didn´t think about that. Just looked at MACH\localization\ which was obviously wrong.
Thanks a lot!
Best wishes,
Joachim
Currently everything is scattered around the folder structures.
The rule of thumb would be to first check the general localization folder, afterwards the one of the application.
What about the english file?
There is no English file, since the source code contains the English text.
Read about translation and localization in the NX documentation.
