NX12 installation problem
First of all - sorry, may be this forum not so best palce for this question..
One of my customer try to install NX12, server installation.
While firewall on server TURN\OFF - NX on client PC working. But if firewall TURN\ON - not working.
Ports 28000-28010 is opened.
Solution "Always SWITCH\OFF firewall" - impossible.
Just now I have not more detailed info like log from server, server OS - later.
May be anybody have a solution for this case?
Thanks!
I have downloaded ugslicensing_user_guide.pdf - no any words about firewall.
Re: NX12 installation problem
Try to add two rules into the firewall, add permisions to run ugslmd.exe and lmgrd.exe. Sometimes I have had to do it in order to make NX run.
Frank.
Thanks, @Frank! I will try and let you know.
