NX1847 I think I found a new problem.
When I use the depth contour milling to open the smooth machining workpiece (layer priority), Tool there is a problem with the calculated tool path when there is overlap distance. This has not happened in previous versions of NX11 and NX12.
If Tool there is no overlapping distance, the tool path is perfect.
I hope that you can help me find the problem and improve it. Thank you
Re: NX1847 I think I found a new problem.
I checked both your prt and there is overlap distance 0 in every operation.
So overlap distace 0 produce also such tool path.
The tool path calculated by the NX12 version is what I want, but it can't be realized on the NX1847. It can be achieved with a 10mm tool, but it can't be done with 30mm tools (it is feasible in NX12)
Is it wrong with my installation software?
Thank you for your answer
I doubt it.
Send it to GTAC.
Here is an alternate solution to get the tool path you desire.
Unable to play video. Please try again later.
(view in My Videos)
Hello jkane1
Thank you very much for your solution. It seems that this method can only be used on simple models. If you encounter complex models, you need to do a lot of auxiliary surface, or the previous version is more convenient to operate and does not need too many auxiliary surface and thread body. I hope to repair it in the updating package in the future. ~Thank you.
