NX9.0 ZLEVEL OPERATION ISSUE
Hi, Guys
Today I met one zlevel issue when I mill radius. Normally tool path is smoothly But now it is snatchy. I am not sure what happened?
Thanks in advanced!
6 REPLIES 6
Re: NX9.0 ZLEVEL OPERATION ISSUE
Someone knows?
Is your geometry good? By that I mean are all the fillets tangent, face normals the right direction, any undercuts that shouldn't be there.  Did you try doing an optimize face to clean up the model?
Jake Hardwick
CNC Programmer
Senior Aerospace AMT
Production NX8.5.3.3 Beta testing NX10.0.1.4
I'm not clear on what you mean by "snatchy".
Can you post a picture of the tool path zoomed in close?
And what are your tolerances?
Mark Rief
Retired Siemens
I post new picture as you refernce!  And I use " Zlevel corner" to program, It is ok! I do not know why?
Thanks!
Hi, Jake
How to optimize face to clean up the model?????
Sorry, I still don't know what you are trying to cut.
If you post a picture, display the part geometry and cut area.
Zlevel_corner is for rest milling material left behind by a larger tool.
If you are trying to machine the blend, I would use streamline. If you really want planar cuts, use zlevel and optimize the cut levels so they don't spread out as the part slope gets flatter.
Mark Rief
Retired Siemens
