Need Help! Material removal in machine simulation in NX 12.0.1 is not working properly.
Hi all
I have recently upgraded Nx 12 to Nx 12.0.1 . Here i am facing a problem that material removal in machine simulation is not working properly. Can any one help me plz
5 REPLIES 5
Re: Need Help! Material removal in machine simulation in NX 12.0.1 is not working properly.
What if blank solid bodies? Will be more better..
Hi
I have tried both options ,Boundry Block and solid geometry but result in both options is same.
Is there any other option for configuration of Material removal in Preferences and Costumer defaults????????
Do you have a spindle speed programmed...
I can't really tell from your graphic, but it looks like your tool is below the top surface
@Michael_Mannino @Chigishev
Thank for your reply , actually i had set flute length of cutter too short thats why meterial cutting in simulation was not showing.
