Need Help again....FLowcut Operation
Builder
Builder
Good day,
 Need help on Flowcut operation, cannot create toolpath as shown in the image. I want to use reference tool option.FlowCut_Reference_Tool_Operation.JPG
NX Version 12.2
Thank you always.
Jayson
5 REPLIES 5
Re: Need Help again....FLowcut Operation
hi,
I see no image
The "yield" sign is an issue that has cropped up the last day or 2 for in-line images.
You need to attach your image as an attachment.
Builder
Builder
Good day,
Thanks for the response,
I have attached the image.
Thank you always
Hello @sanji ,
thanks for sharing the picture.  I can see the toolpath splits up in that one area. Can be a couple of reasons why it is doing that.
I would kindly ask you to report this to GTAC (including uploading the part file), so that we can investigate what is going on.
Additionally I will check the toolpath in our brand new Flow Milling algotithm.
Thank you in advance!
Cheers,
Alexander
Lead Product Manager - Mold & Die
Builder
Builder
Hello Alexander Freund
Thanks to your response, I have sent the report and the part file to GTAC as you advised.
Thank you always,
Jayson
