Need solution for post
How to solve this problem "error in end point of circle"
when i'm machining circle job,show this error with some programs
controller siemense 828d & 810d.
26 REPLIES 26
Re: Need solution for post
Which post you use Postconfigurator oder Postbuilder. NX Version ?
You can swtch Circle Output from FULL_CIRCLE to QUADRANT
That was the fix for me when I ran into that problem.
Hi @Patel
Are you using I J or R in the G02 G03 circle definition?
Paul
@Paul_Hartrick YES i'm using I J in the G02 G03 circle definition.
@Patel
Ok, i would also make the circle setting FULL_CIRCLE to QUADRANT and see if the issue goes away.
Paul
@Paul_Hartrick sorry but i'm not understand what you say.
@Patel
find the setting here.
Paul
ok , i'm check it.. and thanks
i was check in my post processer but its already show "quadrant" option.
