Normal to
How does one put themself "normal to" a face?  I'm looking for something similar to the "Normal To" icon in Solidworks.
Thanks!
FMJ
Re: Normal to
What are you trying to specify - a vector?
If so, in the Vector dialog, use the type "Face/Plane Normal"
Mark Rief
Retired Siemens
Re: Normal to
If your talking about solidworks, then I would assume that you want the CAD system to view thepart normal to a face. If so then you can select a face or plane and press F8
Using NX 8.0.3.4
Re: Normal to
F8 was the answer I was looking for!  Thank you!
