Not able to select Fact body as Blank
I am using NX12.0.2.9.
I am not able give facet body as Blank.
4 REPLIES 4
Re: Not able to select Fact body as Blank
You might want to update to a newer MP, This is resolved in NX 12.0.2 MP2
http://solutions.industrysoftware.automation.siemens.com/view.php?si=001-9397618
Link is not responding..
The link is to a document on GTAC.
You need full webkey access.
The document linked basically says
FAQ
Unable to add Facet Body as stock
Solution
Solved
Thanks for your valuable input
