Nx Asking for Blank defination every time,,,why??????
Hi
I have created a tool path on a very simple part for practice. I defined Blank and workpiece geometry correctly in operation nevegator geometry but when i try to verify my tool path with 3D Dynamic option . Nx always ask me to define Blank. Why??
I know its a very simple question but i expect from you guys that some may help me in resolving this issue.
Re: Nx Asking for Blank defination every time,,,why??????
Put your operations into the workpiece.
You have them on the same level with workpiece in the MCS and they dont see workpiece.
@Juraj
I have already put my both operations under the workpiece as seen clearly in the screen shot(Already Attached),but getting same result.
Not below the workpiece, but inside of it, so that they are children of it.
@AaghaFarhan
@Juraj
Check this please , i think i have done this already as you instructed.ssssss.JPG
Thank you @Juraj and @Stefan_Pendl
I got the point where i was making mistake,issue is resolved
Thank you
For others to make things clear, the display of the operation navigator and the dependencies pane must look as shown in the image below.Workpiece_used.PNGWorkpiece used by Operations
Hope this helps.
