Re: Nx12 adaptive milling
Awesome
Like I said been looking forward to this tool path (for quite a few years now)
hi
  Thank you for your answer.Smiley Happy
   Will Adaptive Milling support a low version of NX?For example, NX 8.5
It is not a separate add-on, it is part of the NX distribution, so it will be available starting with NX 12.0 and there will be no back-port possible.
HI Alexender ,
I am Looking forward to this.
I am wondering when roughtly is release for this bottom up command in Adaptive milling . This is because I will need to feed back my customer .
Thank You .
Best Regards,
Edwin
The NX 12.0.2 EAP contains bottom up machining, so it should be released in NX 12.0.2, this has also been mentioned by Alexander in other threads.
@Edwin_DTS
January 2019 :-)
Lead Product Manager - Mold & Die
@Stefan_Pendl
Unfortunately it won't be in the NX12.0.2 release, but in the release after (January 2019)
It is still testable in the EAP. So interested people can contact me.
@AlexanderFreund
@Stefan_Pendl
Thanks for your reply and info.
Best Regards,
Edwin
@AlexanderFreund
Is there any possibility to get a video ? Our customer would like to see. Thanks You.
Best regards,
Edwin
Hello
There is a Video from "prolim" in Youtube wich shows the new operation and compare the new adaptive milling with the older cavity milling.
https://youtu.be/XNSijdJccHA
They told in the video this enhancement would be included in NX12.0.2 it is a little bit confusing.
Best Regards
Production: {NX 10.0.3.5 MP18}
Testing: {NX 12.0.2.9 MP03}
