03-13-2017 05:03 PM
I am struggling with MTB and CSE on how to have a lathe tool in a head rotary - spin a table spindle and cut a workpiece. I see sim 9 has one siemens sample of using a lathe tool from various head rotary affected positions (but not while cutting.) The tool/head compensation method is not visible in cse. If I decide to change the head rotary while cutting - does this require a kinematic chain? Will the milling type chain work for turning operations?
Solved! Go to Solution.
03-14-2017 05:49 AM
are you aware of the documentation sim09_mill_5ax.pdf shippded since NX11.0.1 in the folder:
..MACH\resource\library\machine\installed_machines\sim09_mill_5ax\documentation
Here you can find more detailed information.
03-14-2017 09:07 AM
All is well and working - nevermind. I will look at the added doc in NX11 - thanks.
