Okuma Work Coordinate Selection
I'm used to Fanuc with work coordinate selection being G54-G59 or G54.1 P.
On our Okuma it's G15 H1-H99.
Any ideas on how to handle this in PB (10.0.3)?
Re: Okuma Work Coordinate Selection
there is always many ways.
One of them:
create new address, name it,
leader: G15 H, expresion: fixture offset variable (find it throgh debug or in variable browser)
set modal, or non modal
Put this address as  a block in some section, start operation initial+first move for example.
If you are new to PB watch all videos about PB on this page and sme on youtube.
Worked great, thank you.
To whom is may concern:
It might be worth noting that the variable $mom_work_coordinate_number (as used by the G-Work Coordinate Selection word) generated an error message.
The variable $mom_fixture_offset_value (as used by the G - MCS Fixture Offset word) worked great.
