Oper attribs and expressions
I should be shot for not seeing this in the release notes but something good has come about with NX8 +.  I just discovered that operation attributes can be linked to expressions.  Now that could be very useful in the right circumstances.
Well done developers. Smiley Happy
George
George R. Bennett
GRB Consulting
W7 Ult
Various NX versions from 6 to 9
Dell Precision M6700
Re: Oper attribs and expressions
George,
You're welcome, but the credit goes to the NX team that maintains the attributes and expression systems, since attributes in CAM are just NX attributes.
One of the advantages of being part of an integrated system is that by using standard NX architecture, all the applications (including CAM) benefit when NX makes enhancements.
I noticed this when we added attributes for operation tooltips. If you look you'll see that I used a category NX$CAM_TEMPLATE and defined them as string types.
Mark Rief
Retired Siemens
