PAX-File with included templates
Hello! I have a question to PAX-Files. Following situation: We work in managed mode with TC and I want to manage the tempates exclusive in the PAX-File. This does not work.
In my PAX-file I have the following entries:
<PaletteEntry id="d1001">
<References/>
<Presentation name="TEST Setup" description="CAM Test Setup">
<PreviewImage type="UGPart" location="${UGII_CAM_TEMPLATE_PART_METRIC_DIR}cam_test.jpg"/>
</Presentation>
<ObjectData class="CamTemplate">
<Filename>@DB/cam_TEST_setup01/0</Filename>
<Configuration>${UGII_CAM_CONFIG_DIR}cam_test.dat</Configuration>
<LibraryClassPath>SETUP_TEMPLATE;MASCHINEN</LibraryClassPath>
<Units>Metric</Units>
<UsesMasterModel>Yes</UsesMasterModel>
<ItemType>MENCMachining</ItemType>
<RelationType>master</RelationType>
<FileNew>Yes</FileNew>
<Libref>1111</Libref>
<TemplateClass>2222</TemplateClass>
<TypeTemplates> @db/mill_multi-axis_metric_NX10_Update/B</TypeTemplates>
<TemplateDescription> General Assembly for TEST</TemplateDescription>
</ObjectData>
</PaletteEntry>
=> I only want to get the template mill_multi-axis_metric_NX10_Update/B if I create an operation in NXACM. This does not work.
What I found out:
1.) If there is an accordance between PAX-File and template_part_planner.dat NXCAM uses the templates specified in template_part_planner.dat in TC
e.g.
Entry in PAX-File: <Filename>@DB/cam_TEST_setup01/0</Filename>
Entry in template_part_planner.dat: DATA |1000| 9000 | @db/cam_TEST_setup01/0 | @db/mill_planar_metric_NX10_Update/B | TEST | metric
=> You get mill_planar_metric_NX10_Update/B if you create an operation in NXCAM
2.) If there is NO accordance between PAX-File and template_part_planner.dat NXCAM uses the templates specified in the OPT-File whitch is listed in the configuration-DAT-file.
e.g.
Entry in Configuration-DAT-File: TEMPLATE_OPERATION,${UGII_CAM_TEMPLATE_SET_DIR}cam_TEST.opt
Entry in OPT-File: @DB/hole_making_metric_NX10_Update/B
=> You get hole_making_metric_NX10_Update/B if you create an operation in NXCAM
3.) If I don't have an entry in configuration-file with the keyword TEMPLATE_OPERATION NXCAM produces an error if I make "File New". => This is no option
4.) If I have an empty OPT-File "File New" works but if I want to create an operation NXCAM says that no template file does exist and I should reset the configuration.
When the entries from the PAX file to be considered?
What's the way to solve the problem?
Thank you all.
Werner
Werner
Production: NX12.0.2, FBM | TcUA 11.4.0.6
Development: VB.NET, Tcl/Tk
