PMI In Reuse Library
As the title suggests, I was wondering if I could save PMI to an object that I'm adding to the Reuse Library?
4 REPLIES 4
Re: PMI In Reuse Library
Could you give us some more detail? I'm not sure this is a CAM question.
Mark Rief
Retired Siemens
Hi Mark,
I guess it is more of a Design question but I'll explain. I'm storing a bounding body feature with Synchronous Modeling done to it with top and bottom datum planes. I'd like to attach some PMI to it that gives me the length of the box in the X, Y and Z direction. This box will used to quickly adding a rectangular billet to my parts.
I don't have an answer, but I'll leave the post here as some CAM folks might.
I suggest you also ask in the Design Forum
Mark Rief
Retired Siemens
Alright, thanks Mark
