POST_BUILDER HELP
How to change the unit of a post from inch to mellimeters if is possible
Re: POST_BUILDER HELP
create new post with the same axis/kinematics,
switch to mm,
controler - users - pick your inch PP
OK
save your mm post
You could also create a units only post for mm, that references your existing inch post.
Mark Rief
Retired Siemens
