POST Configurator - COMBINE ROTARY - FANUC
I'm trying to get the COMBINE ROTARY function in PostConfigurator for Fanuc 4axis, but I can't. It works for the TNC, but when I put the same code in Fanuc with a few things that are just for the TNC, nothing happens. Has anyone tried it for the fanuc and does it work?
Thank You
PaLi
https://community.plm.automation.siemens.com/t5/Discussion-Forum-NX-Manufacturing/POST-CONFIGURATOR-...
