Parabolic Performance Cutting - ton cutter
Hi together, does NX have a possibility to create ton cutter for milling out of the box? And does NX have an operation for conic ton cutter? If not, which operation would you suggest? Best regards Frank
6 REPLIES 6
Re: Parabolic Performance Cutting - ton cutter
Sorry.... What is it "ton cutter"? Thin cutter? Sorry for my English..
Google help me  - I found article for PPC. "Barrel" tool is a same?
This topic interesting for me: what about BARREL TOOL from NX? Of course, non-parabolic, but radius. barrel.png
I open some HOFFMAN webpages - I dont understand why "parabolic" - true radius, huge radius, Rw=500 (for example).
You can use BARREL TOOL from OOTB
I think - exactly as you need:
Just odinary VARIABLE CONTOUR
Siemens Legend Siemens Legend
Siemens Legend
Thanks Yury,
in NX1847 we already have a better way to define the tangent Barrel:
in NX 1872 you will be able to easily define Taper Barrel (ignore the ugly temporary pictureSmiley Frustrated):Taper Barrel.jpg
Eddy Finaro
NX CAM Product Manager
Siemens PLM
