Pocketnc 5-axis benchtop mill
Has anybody here used a pocketnc machine? http://www.pocketnc.com/pocketnc/pocket-nc
It's a ligthweight machine suitable for soft materials.
I recently purchased one and am waiting for delivery. I will build a Machine Kit for it using post configurator. Nice learning activity on a real piece of hardware.. I was wondering if anybody else has done this or programmed for this machine?
https://youtu.be/kcioWRBSjOc
Paul
16 REPLIES 16
Re: Pocketnc 5-axis benchtop mill
Hello Paul
Did you know which Controller this machine has? S840D or Fanuc or Fanuc like?
Postconfigurator support in the moment following controllers (Heidenhain,Siemens,Fanuc;Okuma)
Heinrich
It's fanuc like. It's using an app called machinekit. Runs on a beagle bone black. The post and machine is easy. I've already built an Alpha version.
Paul
Just to update eveyone. I have a production working post and machine simulation that has been tested on the machine. Built with Post Configurator.
If anybody want's a copy send me a note. I'll also get it on kit staore bit that will take a little longer.
Paul
Good day
Realising that the below is an older post from a year ago would it still be possible to share the Pocket NC V2 post processor and machine simulation file? I would really appreciate any help in this regard as I would like to use Simens NX CAM to post programs for the machine.
Best regards
Mike
Good day
Would it still be possible to share the Pocket NC V2 post processor and machine simulation files for NX? I would really appreciate it as I am no expert in creating posts.
Best regards
Mike Saxer
Hi @Mikey_77
Sure, It's at V3 now and a little bit safer if you forget good engage and retracts in 5-axis.
Paul
Hi PAul
Thank you so much for the fast response. So the attached you sent will work for V2 machine still?
Hi Paul
Sorry, another question. How do I go about installing the post .MTK file you sent in NX? Is there a step by step on how to do this? Sorry still a bit new to NX.
Best regards
