Polar mode CSE issue
Hi!
I´m programming a millturn machine (Mori Seiki NLX2500) CSE Simulation.
I work correctly with turn mode and mill mode separately. I use G112 for milling operations.
But when i try to work both modes together i get the next error:"No feed value set. Linear motion will not be executed. " But in NC-code it exists Feed programmed in the linear move line.
I managed to fix the error chaging FanucFamily.CCF to the last update (21/19/2015) from sim10 sample. But with this change Polar Mode (G112) it no longer works.
Why could be this issue?
What I can do?
Best Regards,
Ivan
Re: Polar mode CSE issue
Hi Ivan,
Try to add G94 or G95 in the G01 or G02/03 line to define the Feed Unit.
I hope it helps.
Jean Marcel
PLMPRO
www.plmpro.com.br
Hi!
Thank you! It works!
But why with teh last uodate of cse parser G112 doen´t work¿?
Best Regards
Ivan
