[Post Builder] Caxis rotation error
Solution Partner Innovator Solution Partner Innovator
Hi
I am setup a 4-axis table type machine.
I have one question.
The output is normal when output is single operation.
However, when other operations exist in front, the coordinate values are changed.
Why?
Thank you for your advice.
Re: [Post Builder] Caxis rotation error
Hello
Please set mom_kin_rotary_axis_method to Zero in your ...tcl File
set mom_kin_rotary_axis_method "ZERO"
The changes were not resolved.
Is there any other way?
I see also another issue the post try to use the shortest way also for linear moves.
Try to insert anywhere in the MOM_end_of_path procedure.
global mom_pos
set mom_pos(0) 0.0
set mom_pos(1) 0.0
set mom_pos(2) 0.0
MOM_reload_variable -a mom_pos
Hope this helps
