[Post Builder] Delete tool information output code
Solution Partner Innovator Solution Partner Innovator
Hi
I refer to sim08_mill_5ax_sinumerik_mm.
The following code is generated at the time of output.
I want to delete the code block.
N250 ;TOOL,AM_LASER
N260 ;TLDATA/MILL,0.5000,0.0000,2.0000,0.0000,0.0000
N270 ;$$ centerline data
But I have not found where it is set.
Do you know where it is set?
Re: [Post Builder] Delete tool information output code
This kind of output is usually contained in CLS files, since it is APT format.
Are you sourcing a CLSF.Tcl file?
