【Post Builder】How can I output the group name through the TCL command
Hello everybody
How can I output the NC program by TCL command.
Do not output the top-level group name _...
I want the output A1.nc     A2.nc  ......
4 REPLIES 4
Re: 【Post Builder】How can I output the group name through the TCL command
The naming is handled in the system file "%UGII_BASE_DIR%\MACH\resource\postprocessor\ugpost_base.tcl" in procedure "OPEN_files". look for variable "mom_sys_group_output".
Might be best to create your own Tcl file containing a customized version of the procedure and source it in.
Production: NX12.0.2, VERICUT 8.2, FBM, MRL 3.1.7 | TcUA 10.1 MP7 Patch 0 (10.1.7.0) | TcVis 11.4
Development: C (ITK), .NET, Tcl/Tk Testing: NX (1876) | AWC 3.4 Preparing: -
I know this method,I want to embed it directly in the reprocessing.
How do I do that?
Copy the entire OPEN_files procedure to the user TCL file that is sourced by the post-processor.source_user_tcl.PNG
Change the line:
set grp_ptp_name "${mom_output_file_basename}_${group_name_lowercase}${output_extn}"
To:
set grp_ptp_name "${group_name_lowercase}${output_extn}"
That is all.
thanks
