Post Builder - How to grab text status from tool output info in an operation
Is there a variable where the "Text Status" info in the tool output section of an operation is stored?  I want to use this as a trigger for probing the tool.  Currently I use a UDE that I made and then just use that in a procedure.  However, I am now working through a network and don't have access to the ude.cdl file that I had modified and so I am looking for another route.  Any suggestions would be appreciated.
Re: Post Builder - How to grab text status from tool output info in an operation
Got it.  used the following.
global mom_tool_text
if { [info exists mom_tool_text ] && $mom_tool_text == "1" } {
MOM_do_template tool_change_with_g200
} else {
MOM_output_literal ""
