[Post Builder] Program group name
Hi
I want to print the group name under the program group.
Is there a way to print it?
How do I set it up in Post Builder?
Thank you for your help
Re: [Post Builder] Program group name
try "mom_group_name" or "mom_parent_group_name"
or define a proc for MOM_start_of_group
Ken, does this only work for PB?
Cannot get it to respond  or take it without an alarm in .tcl file output.
I ran the debug and mom_review and I see that it is present to grab...
Maybe my setup is not right. Not sure.
In which event are you using the variable?
Did you specify it as global variable?
Did you check that it exists before you use it?
Can you post the portion of the NX syslog that complains about the variable?
An example entry is shown below:
************* MOM: TCL SCRIPT MESSAGE *************
User message: can't read "mom_contact_status": no such variable
    while executing
"# Compiled -- no source code available
error "called a copy of a compiled script""
    (procedure "LIB_SPF_center_of_ball_output" line 1)
    invoked from within
    (procedure "MOM_before_motion" line 1)
    invoked from within
"MOM_before_motion"
Hope this helps.
Thanks, That was my problem
Was trying to pull from the wrong group The variable was not in the first group. Moved it to the second. Now it reports.
Thanks for the heads up. I think I am catching on.
