[Post Builder] Window10 - output error
Solution Partner Innovator Solution Partner Innovator
Hi
I am doing a post builder.
I used the following code to output some value to the program start position.
On Window7, the output is normal. On Window10, the following problem occurs.
The process can not access the 'Because another process is using the file' window.
The contents of the virtual file can not be edited and deleted. I do not know where to change. Thank you for your advice.
Re: [Post Builder] Window10 - output error
Siemens Genius Siemens Genius
Siemens Genius
Hi kimies_saida,
this seems to be an error, could you please open a ticket with our support, so we can have a look into this:
Thank you,
The 2 lines "puts (ITEM" and "puts (TYPE" need a channel
e.g. the "$handle_w" in:
puts $handle_w "(TYPE : $mom_in_type)"
