Post Builder ask expression
Hello all,
I have been using the following code for a while now to output the value of an expression at the end of my program. If there is no expression that is specified in the code(in NX8.5), it would ignore and move on. Now, when testing NX10, I am getting an "Undefined Expression" error, when no expression is there. Anybody know why?
Thanks in advance,
Ron
Windows 7 64-bit
NX8.5, testing NX10
global mom_sys_control_in mom_sys_control_out MOM_ask_ess_exp_value
set co $mom_sys_control_out
set ci $mom_sys_control_in
catch [set expVal [MOM_ask_ess_exp_value EXPRESSION1]]
if {[info exists expVal ] &&
![string match "No such variable defined in Expression" $expVal ]} {
MOM_output_literal "$co\EXPRESSION1 = $expVal\ $ci"
14 REPLIES 14
Re: Post Builder ask expression
I think someone already mentioned (in a thread) the need to put catch around it after a particular version of NX. Expressions (function of) has been enhanced in the last NX versions. I think the post can write them now.
NX12.02
Windows 10 Pro
Looks like something I'll have to remember to test in our upgrade.
Try adding a "MOM_output_text expVal = $expVal" (or MOM_output_to_listing_device) to see what it is really returning, and adapt your logic to suit.
Ken,
I don't get any output when I add your suggested code. I added in multiple different locations in the code. Where would you add it to get the value of expVal to output?
Ron
Maybe I should have applied more thought...
Try something like this for an expression that doesn't exist.
Then adapt logic as needed
set exp_name "EXPRESSION1"
catch [set expVal [MOM_ask_ess_exp_value $exp_name]]
if {[info exists expVal]} {
     # TODO: add logic here to parse returned value for "does not exist" test string
MOM_output_literal "$co\$exp_name = $expVal\ $ci" } else { MOM_output_literal "$co\$exp_name does not exist?\ $ci" }
BTW, global is meant for variables, not for functions, so remove MOM_ask_ess_exp_value from the global variable declaration.
Thanks for the help guys, but still no dice. I also tried a string of "Undefined expression" also. That error was listed in the syslog.
    MOM_output_literal "$co\Expression1 = $expVal\ $ci"
} else {
Take out the "string match" in the first expression?
Won't let me. "Custom command error"
I would do it this way:
catch {set expVal [MOM_ask_ess_exp_value $exp_name]}
if {[info exists expVal ]} {
} else {
 I think that curly braces are better for catch and you should just have to see if anything came back from MOM_ask_ess_exp_val call.
NX12.02
Windows 10 Pro
