[Post Builder[ output the sub program
Solution Partner Innovator Solution Partner Innovator
Hi
I want to print the sub program at the end of the main program.
Currently, subprograms are output as separate files.
However, we want to output the following in one main program file as below.
Sample or advice on how to set it up.
I would appreciate any sample or advice from you on how to set it up.
4 REPLIES 4
Re: [Post Builder[ output the sub program
have you tried the ken's response ? your post
Production: NX11.0.2.7,VERICUT 8.1.2
Development: Tcl/Tk, Gnuplot
www.adgroupe.com
Hi mkn
I saw ken's advice well.
But at the end of the program, I do not know how to put the contents of the subprogram file into the main program.
If subprogram is written to a temp file add something like this to the "End of Program" event
proc PB_CMD_subprogram_append { } {
    global sub_file_name
    global ptp_file_name
    if {[info exists sub_file_name]} {
        if {[file exists $sub_file_name]} {
            MOM_close_output_file $ptp_file_name
            set out [open $ptp_file_name a]
            set in [open $sub_file_name r]
            fcopy $in $out
            close $out
            close $in
            MOM_remove_file $sub_file_name
            MOM_open_output_file $ptp_file_name
Thank you agrivas.
It has been resolved.
