[Post Builder] rotational drill angle
Solution Partner Innovator Solution Partner Innovator
Hi
## Information
1. Version : NX11.0.2
2. Machine Type : Horizontal Table-Table BC Type
3. Question
: I'm doing Post Builder. I would like to ask you about how to drill with the C-axis rotating.
How do I print the process on the leftright as a code block on the right?
Please make sure that you have made the process incorrect or that there is something you need to set in P.P.
