Post Building Help - negative arc value
I'm building a post for a machine that requires a negative value for an arc when mom_arc_direction = CLW and positive when direction is CCLW. I tried to put a formula in the expression field of my user defined "R" word, but this did not work.
What would be the correct way to do this?
7 REPLIES 7
Re: Post Building Help - negative arc value
What do you mean by id did nto work - was there an error message?
What expression did you use to replace $mom_arc_radius?
Mark Rief
Retired Siemens
TCL ERROR. Invalid address expression. My guess is the formatting is wrong...
if{$mom_arc_direction==CLW}{
-$mom_arc_radius
}else{
$mom_arc_radius
Assumeing there isn't a toggle to do this.
What I would do...
1) Create a "PB_CMD_RBarn_Set_Arc_direction"
In it, have code like:
global rbarn_arc_factor
set rbarn_arc_factor -1.
}else{
set rbarn_arc_factor 1.
2) Is the "R" word, change the value to "user defined, and set it to
 "$mom_arc_radius * $rbarn_arc_factor"
Thanks for the reply Ken but I am still getting a TCL error. I had to add "global mom_arc_direction".
}else{
"doh!" (sorry) I forgot one crucial step:
Add the call to the PB_CMD_* before the block in the arc move event
(so rbarn_arc_factor gets defined before the R word tries to use it)
A logical expressin directly in an address is not supported.
I got Ken's custom command to work :*)
Custom command in motion block:
global my_arc_factor
if { $mom_arc_direction == "CLW" } {
set my_arc_factor -1.
} else {
set my_arc_factor 1.
In R word user defined expression:
$mom_arc_radius*$my_arc_factor
Mark Rief
Retired Siemens
Thanks Ken, that worked!
