Post Configurator BLK FORM
Hi All,
With the OOTB PC post for Heidenhain the values for the BLK FORM are always set as shown below.
Does anyone know where these values come from and if they can be filled correctly?
BLK FORM 0.1 Z X-500 Y-500 Z-500
BLK FORM 0.2 X500 Y500 Z500
Sven Voeten
Pre-sales NX CAM / Manufacturing Consultant
cards PLM Solutions
5 REPLIES 5
Re: Post Configurator BLK FORM
Siemens Legend Siemens Legend
Siemens Legend
Hi Sven,
first these values are a standard output in default with Post Configurator. At the moment we have no mom-variables which include the values of the blank part, which make sense to have that in future.
So first and recommended solution should be to add an UDE for the BLK and an eventhandler. Important to know is that you have to set the mom_blk_point_1/mom_blk_point_2  variables in the handler.
I have attached also the ude for that, just copy into your layer or create a new one with the cdl editor.
proc MOM_blk_form { } {
global mom_blk_point_min_x
global mom_blk_point_min_y
global mom_blk_point_min_z
global mom_blk_point_max_x
global mom_blk_point_max_y
global mom_blk_point_max_z
global mom_blk_point_1
global mom_blk_point_2
#Put your UDE Handler Tcl here
set mom_blk_point_1(0) $mom_blk_point_min_x
set mom_blk_point_1(1) $mom_blk_point_min_y
set mom_blk_point_1(2) $mom_blk_point_min_z
set mom_blk_point_2(0) $mom_blk_point_max_x
set mom_blk_point_2(1) $mom_blk_point_max_y
set mom_blk_point_2(2) $mom_blk_point_max_z
Due the automatic pretreatment functionality these variables are now collected and output the values of the UDE which is attached to the program group.
2) Just switch the property off in Post Configurator for the Block Form and implement your own logic in the start of program
Thanks for the hint on that, we will try to find a better solution for future.
Best regards
Thomas
Thanks for the fast response, I will test this next week.
Sven Voeten
cards PLM Solutions
The only thing is to copy the following lines in you .cdl File
EVENT blk_form
POST_EVENT "blk_form"
UI_LABEL "Blank definition"
PARAM command_status
TYPE o
DEFVAL "Active"
OPTIONS "Active","Inactive","User Defined"
UI_LABEL "Status"
PARAM blk_point_1
TYPE p
UI_LABEL "Point 1"
PARAM blk_point_2
TYPE p
UI_LABEL "Point 2"
The Point 1 is the the corner with the lowest values and point2 with the highest values.
Hello
I've the very same issue but I've not been able to solve it, I'm doing something wrong for sure.
I've created a new example post process, for itnc 530, with Post Configurator, using just the controller in Layer selection.
I did try @schauerm3 solution
I did copy
EVENT blk_form
TYPE o
DEFVAL "Active"
UI_LABEL "Status"
PARAM blk_point_1
TYPE p
UI_LABEL "Point 1"
PARAM blk_point_2
TYPE p
UI_LABEL "Point 2"
in my "new_post_custom.cdl", and left the BLK FORM property in Post Configurator On.
Still get
I did also try you solution @ThomasJ but I suspect I'm not doing it right.
I've copy pasted the code below in "new_post.tcl" and for the UDE (your attachment) I tried both main CDL and with the custom one.
Switched BLK FROM property Off in Post Configurator and still I get
If I understood it right, I should add this PROC to the start of the program MOM, but I don't know how.
I also tried something like this but I was not sure what I was doing.
proc MOM_start_of_program_LIB_ENTRY {position} {
    switch -- $position {
        "start"
            MOM_blk_form
Got this error in mom_information.out
***** A TCL Error Has Occurred *****
Event Handler: D:\tmp\new_post\new_post.tcl
Event: MOM_start_of_program
Error Info: can't read "mom_blk_point_min_x": no such variable
    while executing
"set mom_blk_point_1(0) $mom_blk_point_min_x"
    (procedure "MOM_blk_form" line 12)
    invoked from within
"MOM_blk_form "
    (procedure "MOM_start_of_program_LIB_ENTRY" line 7)
    invoked from within
"MOM_start_of_program_LIB_ENTRY start"
    invoked from within
"if {1} [subst $\{[subst ::buffer::${00_proc_name}::${00_section}::code($00_tag)]\}]"
    ("foreach" body line 13)
    invoked from within
"foreach 00_tag [subst $\{[subst ::buffer::${00_proc_name}::${00_section}::current_tag_list]\}] {
			set ::lib_ge_buffer_info(proc_id) "[LIB_GE_get_pro..."
    invoked from within
"if {1} $::lib_ge_command_buffer_output_advanced"
    ("uplevel" body line 1)
    invoked from within
"uplevel 1 {if {1} $::lib_ge_command_buffer_output_advanced}"
    ("eval" body line 1)
    invoked from within
"# Compiled -- no source code available
error "called a copy of a compiled script""
    (procedure "LIB_GE_command_buffer_output" line 1)
    invoked from within
    (procedure "MOM_start_of_program_LIB" line 1)
    invoked from within
    (procedure "MOM_start_of_program" line 1)
    invoked from within
Error Code: TCL READ VARNAME
Could you tell me what I'm doing wrong ? I'd like to understand
Have a nice day
Hello
You need only the UDE as described and the setting of the property to ON
No extra code and no  procedure MOM_blk
