Post Configurator Probe Cycles
Does Post Configurator support probing cycles?
Thank you for your time.
Re: Post Configurator Probe Cycles
Bueller ...
Bueller ...
Bueller ...
I'm not sure I get the question - Post Configurator is an authoring tool, not a postprocessor.
I've asked the post team to respond.
Mark Rief
Retired Siemens
Thank you Mark
Siemens Genius Siemens Genius
Siemens Genius
Hello Quaffe,
Posts created with Post Configurator do not support Probing cycles OOTB. You could however customize/add them in by yourself as a separat layer and reuse that for future posts.
Hope that answers your question,
Florian
The next step could be to share the layer with the community Smiley HappySmiley HappySmiley Happy
Best regards,
Hi Florian,
Thank you for your reply.
Would it be possible to provide some more details or an example of how to get started?
Request #2
Request #3
No reason to keep asking ;*)
@FlorianW is not in the office - I will talk to him next week to see if there is a sample available.
Mark Rief
Retired Siemens
