Moved:
Post Configurator Training Material
This post contained Siemens restricted material. The post is hidden until I get clearance to distribute.
8 REPLIES 8
Re: Post Configurator Training Material
We're making sure the material is suitable outside Siemens, then Florian will post the presentations.
Dear Mr. MarkRief
Could you please tell me how I can download these material? I have account for Siemens's partner but I was refused to access download page.
Same as me.
Frank
You need to hear from @FlorianW
Siemens Genius Siemens Genius
Siemens Genius
I reuploaded it to this reply - Can you please try and download it from here?
If that does not work, please send me a PM and I will relay you the information through Emai.
Thanks and sorry for the inconvinience.
Florian
Download is working fine, thank you for all of this material.
I'we been shown the new PC Def file editor in 11.0.2 and that was quite impressive. Great work guys, proud to stay with Siemens on the CAM side. Kudos Siemens!
Other similar UI add-ons to facilitate and speed up the programing? What can we expect in future releases of PC? Or should we just get it onboard now, ready for prod?? (sinumerik for us mainly)
Siemens Genius
Post Configurator is ready for production for a while now, and we do have some well running S840D running projects in the field.
Now is a good time to start using the tool!
Great, we'll get 11.0.2 rolled out later during the day if all goes well. Let's take advantage of our low season period to give PC a closer look. Who knows we might have time to put up one pp for our latest 828D v4.7, that would be amazing already.
Thans for the heads up btw
